Goaway invalid stream
Bonjour,
je me demandais si qqn avait deja eu le message d ‘erreur suivant:
“GOAWAY invalid stream/error code”
il ne m’empêche pas de travailler mais il revient sans arrêt, auriez vous une idée du problème svp?
Never seen this before. Appears to be a server error not a Seamly error:
A GOAWAY frame is an HTTP/2 mechanism used by one endpoint (usually a server) to tell the other that it is stopping a connection. This can happen for routine maintenance or because of a critical error.
Are you using the cloud for for storing patterns & measurements?
@Chareve Please take a screenshot of the error and post it here. Thank you!
Hi @Chareve - can you provide an update? Thank you!
