I tried to install Seamly2D (Ubuntu 16.04 LTS), but everytime I try to install it, i’m getting this :
$ sudo apt-get install seamly2d Reading package lists… Done Building dependency tree
Reading state information… Done The following packages were automatically installed and are no longer required: libllvm5.0 linux-headers-4.13.0-37 linux-headers-4.13.0-37-generic linux-headers-4.13.0-38 linux-headers-4.13.0-38-generic linux-image-4.13.0-37-generic linux-image-4.13.0-38-generic linux-image-extra-4.13.0-37-generic linux-image-extra-4.13.0-38-generic Use ‘sudo apt autoremove’ to remove them. The following additional packages will be installed: libmotif-common libqt5xmlpatterns5 libxm4 xpdf The following NEW packages will be installed: libmotif-common libqt5xmlpatterns5 libxm4 seamly2d xpdf 0 upgraded, 5 newly installed, 0 to remove and 1 not upgraded. Need to get 5 266 kB of archives. After this operation, 79,9 MB of additional disk space will be used. Do you want to continue? [Y/n] Y Abort.
I don’t know why.
I did use the command that are advised before this one (sudo add-apt-repository ppa:susan-spencer/seamly2d sudo apt-get update)
[Edit : I made a mistake when creating this topic, i forgot to introduce me ! Sorry !]
Hello !
I am new here, I am designing a lot of clothes but never used proper sewing pattern (just cutting fabric on view).
English is not my first language, so, sorry if I may be unclear sometimes.
Hi @ElleyLean, welcome to our forum!
Have you considered purchasing a pattern drafting book so you can learn the formulas to make patterns? There are many pattern drafting books available from Amazon. This will help you get started with patternmaking.
Hello slspencer, thank you for your advice ! But, I’m very specific/original about what I’m sewing, so, unless I can buy pattern for part of clothes (like for my biggest issue : sleeves), it’s of no use for me. Or I would buy a whole pattern, or a whole pattern book, to use maybe one or two little pieces
I don’t like to waste things up
To make pseudo pattern, I take fabric and try to fold them to get the result I want, and cut what is useless. I had a bit of result like that. But that really particular.
@ElleyLean, There are some areas on the wiki that may be helpful to you.
I started a tutorial on creating a complete set of pattern blocks with the McCunn system and though it is not finished, it contains some useful stuff. Sleeve Block, McCunn System - Seamly2D
It is also probably worth your while to check out the pattern cloud tool (https://seamly.cloud) that @MrDoo created and look at some of the patterns that are there.
