Hi, need help fixing this file. I have been working on it for days and have been saving regularly. Unfortunately an error came up and now I can no longer access my work. Can someone help to resolve the error? Thanks!!
Hello and welcome to the Seamly2D forum, @yunrie82
I can have a look but I will need the measurement file as well.
I can’t be sure that it’s the “Bunka Missy” measurements I used. So attaching the “Bunka Original” measurements as well, just in case.
Peiyun Bunka Original.vit (1.1 KB)
Thanks @Grace !
The problem is with the pattern pieces that you created, so I deleted them. You’ll need to create them again.
Here’s your file back:
MRS STYLE BOOK EARLY SUMMER 2020 P189_v063x.val (63.6 KB)
And it uses the Missy sizes.
Thank you so much! Really appreciate your quick response and assistance!
