Help recovering file
The program crashed after attempting to add a detail. This happened once before and I was able to import the file into Notepad and fix the corrupted line. This time I’m getting a “tag mismatch” error and this is a little over my head in the coding department. If anyone could take a look at the file and see if there’s a way to fix it, I would really appreciate it.
Thanks! Ranger Jacket Fix.val (93.6 KB) Men’s Jacket Base Sizes.vst (833 Bytes)
Hi @skinnerjeans
I removed that small section that you were working on, so you’ll need to do it again :slight_smile:
Here’s your pattern back:
Ranger Jacket Fix b.val (93.2 KB)
salut ,s’il vous plais si vous pouvez m’aidez je n’arrive pas à sélectionner mes patron avec workpiece tool
