allâinizio ho faticato a trovare la soluzione , io faccio in questo modo , dalla finestra di dialogo margini di cucitura nella prima casella lascio 1; poi una prima volta - nodo A6 before cm.1 after cm. 4 e lascio vuote tutte le altre, poi OK ; secondo passaggio sempre nella finestra margini di cucitura nodo A7 before cm. 4 after cm. 1 lasciando vuote tutte le alte , a me funziona spero di esseti dâaiuto .
Non ho capito gli ordini e non funziona
Ich habe den Ărmelsaum noch nie Ăźber einen Main Path gemacht.
Was bei mir definitiv funktioniert, ist bei Ă6 âBeforeâ CurrentSeamAllowance, âAfterâ, wo bei Dir 0 steht, 4 einzutragen.
Bei Ă7 dann bei âBeforeâ 4, bei"After" CurrentSeamAllowance. Dann sollte der Ărmel einen Saum haben. Wie hast Du es denn bei dem linken Ărmel gemacht?
I think one should take into account the narrowing of the sleeves. If the seam allowance is used to create the hem, the sides of the article need to be at right angles to the hemline to avoid puckering when sewing the garment.
So in this case, I would rather draw the hem allowance into the pattern using the âFlip by Axisâ Tool.
I added an internal path to show where the fold line goes for the hem and left the seam allowance alone. Hereâs what it looks like in my pattern:
Please let me know if youâd like me to explain in more detail how I did this
@Grace
I solved my problem in exactly the same way
