How can i delede blocco bozza "Pezzo dietro"
How can i delede blocco bozza “Pezzo dietro”
If you have more than one block you can just select the base point of the block with the context menu and click Delete Or select the base point and press Delete on the keyboard. It will delete the whole block AND any pattern pieces created from it.
If it’s the only block.. delete the pattern and start a new pattern.
