How can I delete a block to start over in a project? (Shirt with: back, front, collar, sleeve. I’d like to delete the back block because the armhole doesn’t work.)
Thanks to anyone who can help.
Come posso cancellare un blocco per rifarlo da capo in un progetto ?(Camicia con : dietro, davanti, collo, manica . Vorrei cancellare il blocco dietro perchè non mi torna il giro manica.
Thank you so much! I had tried every way to do it but hadn’t succeeded. And it was so simple! Thanks a million. I will certainly call upon your patience and expertise again.
