Hello
i am happy with the efforts and the helpful ness of the forum. there are a few specific issue which i am not able to explain
a Line Perpendicular from A22 to A21 bisecting A28 to A29 at a specific measurement
Hello
Hello & welcome to the Seamly2D forum, @mrl
I’m not 100% sure of what you want to do, but here I’ve created a perpendicular line from A29 to meet the line between A21 & A22 using the Intersect Line and Axis tool:
First select the nodes that create the line that you want the new node to appear on, and then select the axis point node.
To get the 90° angle off the Line A21 to A22, I used the line angle plus 90°, as you can see in the formula. I think this tool may be the one that you need for this exercise
Hello thnksa for the reply the Size of the perpendicular line as to be Hip Round/4
Hi again, @mrl
Another tool that you can use is the Point on Perpendicular tool, but you will need to place a point first and then use the tool from that point:
