How join 2 pieces detail from pattern piece A and B etc
Hello :slight_smile:
I have a problem with join pieces from pattern A and B. It’s in raglan sleeve.
I have bodice (front and back on construction mesh for baby body) in A and sleeve in B. I need to draw raglan sleeve so I must move pieces next to neck on front and back to top of sleeve. Is it possible?
I found on forum topic with raglan but is different situation.
:slight_smile:
We’d like to help you, so please upload your .vit and .val files and/or post some screenshots of the situation. Otherwise we don’t know what to tell you. :slightly_smiling_face: We’re looking forward to seeing what you’re working on!
Hey. Thanks. I’ll send it :slight_smile: I want to do raglan blouse for baby, so I must connect piece of body to top of sleeve.
stanik 4-9mies raglan.vit (1,3 KB)
stanik 4-9mies raglan.val (21,2 KB)
I wonder if there’s a cat (How To OR Newbies?) or some other place we could put a “sticky” post to let new users know to upload their val & vit files when looking for help?
First, draw lines image in the front & back armscyes: image
Then, use the Intersect arcs tool image on the front sleevecap and back sleevecap using the lines you drew in the armscyes. Add curves image for the short segments:
image image
When creating details image, split the sleeve into front and back workpieces: image
Then join image the front shoulder with the front sleeve, and join the back shoulder with the back sleeve: image
Then join image the front half with back half: image
Hey, Thank You :slight_smile: I’m sorry for silence. I did yours directing :slight_smile: It’s done, run and everything is ok.
Bye :kissing_heart:
