How to add a notches
Hello,
I’m very new to patterndrafting with seamly. I have been playing arround and most of the features i have figured out, exept how to add passmarks. I cannot select a notch, the dropdown menu to select a notch is empty. I have add anchorpoints and nodes, but still can’t add a notch, please help.
While you’re in the Paths side-tab, in the Main Path tab right-click, (ctrl-click for Mac,) the node which you wish to be a Notch, & select that it is a notch in the pop-up menu. Then you can edit that notch’s attributes in the Notches side-tab.
I hope that helps!
Yes! Thank you, that was te missing link for me.
