How to add waistline to pattern workpiece
Hello!
I am going from draft to pattern blocks and I am curious how to include or add back in my waist, hip, bust-lines. Is there a way to add them in when adding a new workpiece, or alternatively including those points in the workpiece and adding them in later when I go to add grainline, seam allowance, etc? Thanks!
Hi again, @Natdellas
You can add the bust/waist/hip lines and other pattern placement markings by using the Internal Path tool at any point after creating the pattern panel detail:
Thank you!!! I saw that tool and now I know what it does. Thanks so much
