hi everybody, i make a big mistake and all the second part of my pattern is false. i want to delete it but dont know how to do.
thank you very much
i want to delete all the pink block
Because there are separate dependencies for each point, you’ll have to delete each point separately.
- In Detail mode: Delete any Detail workpieces that use the points to be deleted.
- In Draw mode: Start with the most recent point (A42) and delete it, then work in reverse order deleting the points, lines, curves, etc. If you can’t delete a point, it’s probably in use in a formula somewhere…
@slspencer you are an angel. 1000 thanks
