How To Flip A Pattern?
I mirrored the back body pattern.
Now I’ll draw the front body pattern on the mirrored pattern.
But before that I want to flip It.
Is It possible? How?
You can’t 'Flip" anything. The only thing that you can do is to either Mirror, Rotate or Move.
Either one of these will copy the selected points and curves and you can make changes to the copy created this way using the points and the curves.
If you change the measurements, the original piece will resize and the Mirrored/Rotated/Moved objects will change as well.
You can read up on how to use these 3 (4) tools in the Wiki here.
