I know when you hover over the intersection node It shows the measures.
However It does not show up when I connect to my PC remotely via Teamviewer.
Is there another way to learn this?
Can we modify the status bar settings in the way status bar shows these information?
When I click on a curve It does not show Its measure as well. (While connecting via Teamviewer)
Is there a different language it would be helpful to get Seamly translated into so that you will be able to easily read the text? I’m a sentimental American so it would thrill my little heart to do anything short of actually studying the language in-depth to make this more accessible to you.
When you open the Variables dialog you will notice that it contains several different categories. The default category is “Custom variables.” You will notice that its tab is pulled forward & brightened, & the other tabs are dimmer.
If you want to look up a line length, click on the “Line lengths” tab. It will be pulled forward & brightened as shown here:
If you want to look up the length of a curve, click on the “Curve lengths” tab. It will be pulled forward & brightened as shown here:
We should also note that the Variables and their values are also available in the Fx editor which pops up when ever you click the fx button where ever it is:
