Hi, Sorry I need some help again , I changed a measurement using.”edit current” and clicked on synchronise when I had a message asking if I wanted to synchronise. But when checking the measurements have not changed in my pattern. Thank you Jeanne
you must save the measurements in the seamlyme program then synchronise measurements (again if need be) before you will see the change in your pattern
Thank you very much
