Hope all of you are well, is it possible to extend file’s export’s format to be including HPGL format, also is possible to add IMPORT option in FILE list for import DXF files please, in WIKIVALENTINA was mentioned it is possible to export files in HPGL format but that option not listed in export list, is it possible to add HPGL format to experts list please and the import DXF files as well
welcome, @Jacob. I do not know the answer regarding the export of HPGL format, perhaps @Sue could help with this.
Sadly, the import of a DXF file will not be implemented any time soon because the DXF is a vector graphic representation and the information used to generate the pattern is not included. This was first answered here: Will be Importing DXF available?
@Sue Could you clarify if the HPGL format supported by Seamly2D is HPGL or HPGL2? In a previous post you had alluded to it being HPGL2, which would be a drag for me and my ancient pen plotter which only supports HPGL.
