I cant take all the points with workpiece tool :(
Good morming! I was very happy because I ve finished a pattern but when a I try to select it with “workpiece tool” I can`t! I press shift to take the curve line but to de next point it desapears… what can I do? image
Just keep selecting the points. As you go, the pink line will catch up. This is just showing you that if you finished selecting the point at this point, the curve will be cut.
Once you have all the points selected, your pattern will look whole and then you press Enter to complete it.
