Issue #205: Point from X and Y needs improved tooltip and user prompts (dismine/valentina)
New issue 205: Point from X and Y needs improved tooltip and user prompts https://bitbucket.org/valentinateam/valentina/issue/205/point-from-x-and-y-needs-improved-tooltip
Susan Spencer:
Point from X and Y needs a shorter tooltip and improved user prompts. when the cursor is over the icon in the Point section, the tooltip is: ‘Tool to make point from X & Y from two other points’ This can be shortened to: ‘Point from X & Y of two other points’
The user prompt in the status bar can be changed from: ‘Select point vertically’ to: ‘Select point for X value (vertical)’
And change: ‘Select point horizontally’ to: ‘Select point for Y value (horizontal)’
