Issue #268: Error by creating details from curves
New issue 268: Error by creating details from curves https://bitbucket.org/valentinateam/valentina/issue/268/error-by-creating-details-from-curves
Atlantis89:
If i create a shape with a curve and use the “Seam allowance tool” to create a detail, the curve seems to be replaced by a line.
Draw mode: curve1.PNG
Details mode: curve2.PNG
This is not a bug. User must yourself reverse curve.On Monday, March 30, 2015 at 7:13:47 PM UTC+3, Bad Wolf wrote:
I can confirm this error also you need to pick the spline when you select detail points
Atlantis89:
Draw mode:
Details mode:
I can confirm this error also you need to pick the spline when you select detail pointsOn Monday, March 30, 2015 at 9:14:13 AM UTC-4, Atlantis89 wrote:
Atlantis89:
Draw mode:
Details mode:
