Issue #293: Remove 'File format' field in Layout's 'Save As' dialog (dismine/valentina)
New issue 293: Remove ‘File format’ field in Layout’s ‘Save As’ dialog https://bitbucket.org/valentinateam/valentina/issue/293/remove-file-format-field-in-layouts-save
Susan Spencer:
Save Layout files to SVG format only. Show path & filename when layout file is saved. Show ‘Your design can now be exported to a print file. Go to File/Export to export your file to a print format.’ message.
