I finished my first pattern in Valentina 0.3.0.0 and produced a layout by the new layouting algorithm. Then I saved as pdf. The chatch is, that somehow the file is not in scale (neither as pdf neither as png, neither with inch, nor with centimeters). I went to a professional printing agency and emphrasized that it had to be in scale but it wasn’t. Then I tried everything thinkable at home and it didn’t work. I also tried with only one pattern piece on A4 - but neither the view on my desktop (100%) nor printing it from different PCs and with different options worked.
I just now installed Valentina 0.3.1.0 and it did not work, either.
Hmmm. All of the patterns that I have saved and printed were in scale.
I will try to save layout as PDF then print.On Mon, May 4, 2015 at 6:19 PM, Anonymous issues-reply@bitbucket.org wrote:
Was there ever any understanding of why this was happening?
I am currently having this problem.
When I go to the layout, all of my pattern pieces are larger than they should be. This is true exporting to different formats, or using the tiled printing directly from the interface.
