Issue #325: Check pattern for inverse compatibility. (dismine/valentina)
New issue 325: Check pattern for inverse compatibility. https://bitbucket.org/valentinateam/valentina/issue/325/check-pattern-for-inverse-compatibility
Roman Telezhinskyi:
In some cases if even a file marked with do not supported pattern format version we still theoretically can open the pattern file. Example is empty pattern file.
