Issue #337: Master pattern and derived pattern (dismine/valentina)
New issue 337: Master pattern and derived pattern https://bitbucket.org/valentinateam/valentina/issues/337/master-pattern-and-derived-pattern
preethiraj:
Hi Roman, Is it possible to create a master pattern which is like a sloper and then create derived patterns? Example: Master pattern has waist, side, armhole and shoulder dart Derived pattern is for princess seam only which darts are modified to create the princess seams.
What the advantage is that for any person the master pattern is always there and based on design the pattern can be derived from the master pattern.
From software perspective the dervived software would need to have the master pattern software as the starting point.
Advantage is that if any change is made to the master pattern then all derived have those changes.
Responsible: dismi_
