Issue #412: Error in Detail using 'Segment a Simple Curve' tool (dismine/valentina)
New issue 412: Error in Detail using ‘Segment a Simple Curve’ tool https://bitbucket.org/valentinateam/valentina/issues/412/error-in-detail-using-segment-a-simple
Susan Spencer:
On Ubuntu 14.04 64 bit:
I used the ‘Segment a Simple Curve’ tool to split a curve. Then created two details, each half of the curve should be in only one detail.
The Detail containing the 1st half of the curve is incorrect. The Detail containing the 2nd half of the curve is correct. See attached image. MyNewPattern2.val file is attached, no measurement file required.
