New issue 418: Default height and size
https://bitbucket.org/valentinateam/valentina/issues/418/default-height-and-size
Roman Telezhinskyi:
This is about standard measurements. Sometimes we create patterns that do not support gradation in all height and size combinations. Or we just not sure about correct work. When the program opens a pattern with standard measurements it checks which height and size set as default value. Previously it was value from a standard measurements. But now i made possible to save such a information inside a pattern file.
Additionally i made an option for Tape that allow to set default height and size in dialog “New measurements”.
For example i have a file jacketМ6(30-110).val. I gave the file Valentina and she opened the file with wrong combination height and size (176/50). But how you see from the file name you should use size = 30 and height = 110. And now you can force the program to start with size = 30 and height = 110.
Responsible: dismi_
one thing that might help check this kind of thing is to have a 5
centimeter/1.5 inch square in one of the corners this way after
printing if you measure the square and it is NOT the correct
measurement something went wrong. Your solution should stop things in
the beginningOn Sun, Dec 13, 2015 at 2:05 PM, Roman Telezhinskyi issues-reply@bitbucket.org wrote:
Roman Telezhinskyi:
Responsible: dismi_
You received this message because you are subscribed to the Google Groups “Valentina-project list” group.
To unsubscribe from this group and stop receiving emails from it, send an email to valentina-project-list+unsubscribe@googlegroups.com.
To post to this group, send email to valentina-project-list@googlegroups.com.
Visit this group at https://groups.google.com/group/valentina-project-list.
For more options, visit https://groups.google.com/d/optout.
Robert L Martin
