Issue #444: Length along Path seems not valid
New issue 444: Length along Path seems not valid https://bitbucket.org/valentinateam/valentina/issues/444/length-along-path-seems-not-valid
David Arnold:
Using the Length along SplinePath Tool:
The first image shows the bigger picture, the blue dotted line on the bottom are the reference lines, used for measurement. The second enlarged image shows the transition of the points from the blue reference line onto the Spline Path. As it can be clearly seen the path-bound distance between those two points on the Spline Path do not match de reference distance.
@d-old Can you tell me, which tool is meant here? I don’t find a tool named “Length along SplinePath Tool” or anything that seems to match a function like this…
This is about the tool “Segmenting a curve path”.
I understand! Thanks for the info.
