New issue 527: Pasting a wrong formula : every dialog box is “glued” to the screen and can’t close file or Valentina. https://bitbucket.org/valentinateam/valentina/issues/527/pasting-a-wrong-formula-every-dialog-box
mil sv:
Hello,
So something weird happened and I thought you’d like to know :
I was working on a new pattern, just had maybe two lines drawed. I was creating a new point and wanted to paste a formula I had used and copy previously ; but apprently I did not copied it right so instead I pasted a few lines of text I had copied before. THe surrounding of the dialog box for creating points went black, and then all the windows or boxes I oppened just stayed “glued” to the screen. I can’t close this pattern file or Valentina at all. But if I create a new file this one works perfectly. Also the file that bugged is now a transparent or black window .
I made screenshost so you see what I’m talking about :
So this is not a huge deal as I kind of know what created the bug and it was my mistake, but I thought you might want to know about that.
Thank you so much for your great work ; I use Valentina on a daily basis and it’s been such a huge time saver for me !
