Issue #533: Error: Layout Margins not used in layout view (dismine/valentina)
New issue 533: Error: Layout Margins not used in layout view https://bitbucket.org/valentinateam/valentina/issues/533/error-layout-margins-not-used-in-layout
Susan Spencer:
Ubuntu 14.04 64bit, Qt 5.7 Valentina 0.5.0.1337a Build 7c8225974b38
Top,Left,Right,Bottom margins in the Layout dialog aren’t controlling the margins in the layout that appears.
When I use File/Layout/Print the images are incomplete at the margin.
When I use File/Layout/Preview the margins are correct.
In the attached images: Top,Left,Right, and Bottom are 2cm. The Layout in this image is A4 paper, these pattern pieces are very small. My printer and plotter don’t print that close to the edge of the paper.
