Issue scrolling horizontally with trackpad
I started using Seamly recently and have enjoyed using it very much. There’s one issue which has made me a little frustrated, which is horizontal scrolling with a laptop trackpad doesn’t work. I’ve downloaded the source and made a simple fix, which I would like to contribute back to the repo. The github issues page states that a post should be made here first - so here I am!
The problem: there is a shift key modifier set up to scroll horizontally, which would work great when using a mouse with a wheel, but it conflicts with normal horizontal scrolling using a trackpad (and I assume would also conflict when using a horizontal scroll wheel on a mouse that has one). My fix moves this functionality to a new but nearly identical function to the existing vertical and horizontal ones, rather than taking the place of the horizontal one, which allows the normal horizontal scrolling to take place.
Fantastic! Did you build your branch and run it on your laptop? What version of Qt did you use?
Yes, I have a branch with my changes in it - well, on a Ubuntu VM on my Macbook, where I have been running Seamly. Qt v5.9.5.
Hey what’s your github id? I’ll add you to the repo so you can create a pull request.
I’m koshaugh there too.
