Hello, I’m using seamly in a while, so cool! but I have an issue now, for print my pattern for cutter machine they ask me to use the hpgl, so I open my svg file in inkscape and I save in hpgl. No problem for the print, but the label disappear. In the print came out the pattern and the grainline, no label? it is possible to fix this problem? thanx a lot! Paola
Hello and welcome @paolarobiolio1.
Is that the file hpgl? If so, then it could be that hpgl is a cutting file and doesn’t cut out the labels.
Hello Grace, I was thinking that but the patterns of the other user with different program came out with label! looks that some get lost in the conversion form svg seamly format in hgpl format. thanx!
thanx I fix the problem. I just need to sign when I save the pattern as sgv text as a path.
Oh, wonderful I don’t know much about cutting machines, etc. - I’m only a home sewer
but I tried to help.
