When I want to switch from Detail mode to Layout mode, the program crashes. Am I doing anything wrong or is it a bug?
Can you provide more information? I switch from detail mode to layout mode and the program does not crash for me. Is this something that you can reproduce every time? Do you have a specific .val and .vit file that will demonstrate the problem? If you can provide enough detail to duplicate the problem it will be easier for someone to help you work around it and get the software fixed so that it does not crash.
Also, can you provide a screenshot or write down the information about the specific version of software you are using and the date and time of the build. These will be found by selecting the help menu and the “About Seamly2D” item from the menu. Also, what computer operating system do you use? Windows, Linux, MacOS? What version.
Thanks
