Learning Seamly
Hello Seamly family,
It’s been almost a month that I am learning seamly, It’s an amazing and very accurate software. During my learning journey I came up with few questions. I will be very thankful if anyone can answer my questions.
  1. What are variables, what are they used for?
  2. Should ease be added through formula or it can be added manually?
  3. In which situations adding manual measurements won’t hurt? Any examples?
  4. Should all the curves and lines be drawn CW or ACW? or its personal choice?
  5. Sometimes if I add a point or line, it automatically goes to the hidden group, Is there any solution to this?
  6. Is there any way you can formulize the curve length i.e. waist side to hip side?
  7. What are the standard seam allowances in US? Currently I am adding 2cm side seam, 1.5cm shoulder, 5cm at straight hem (4cm fold, 1cm allowance), 1cm everywhere else.
There’s basically 2 types of variables ( 3 if you include “measurements”). There are Length and Angle variables created by the tools, and Custom variables create by the user. Variables are stored in the pattern file, unlike measurements which are stored in measurement files.
Let’s take the simple point A1, which creates a line length and angle variable:
The length is designated by “Line_” followed by the 1st and second points… thus Line_A_A1. The angle is designated by “AngleLine_”. follwed by the points… AngleLine_A_A1. If we look at the Variables table we can see the line variables and the values:
Now you can use those variables in formulas. For example let’s draw another Point - Length & Angle using those variables… using the FX editor let’s set the length of A2 to the length of Line_A_A1:
and the angle to AngleLine_A_A1 + 45:
We now get the Line_A_A2 with the length of A to A1 and an angle of 45 deg.
Now for Custom variables (prefixed with a hash #)… let’s add a variable called “ease” and give it a value of .75:
Let’s add “ease” to the length of Line_A_A2:
So now the length of Line_A_A2 is .75 longer than Line_A_A1. If you hada buch of formulas with “ease” youmcan change the value of the variable ease without having to change every formula. You can also use if / then / else syntax in the formulas to dynamical change the ease, but that’s beyond the scope here.
Third case… measurements + a custom variable. Let’s create point A3 with the @waist measurement + #ease:
IMO… while you could create a custom “ease” measurement, it should be added as a Custom Variable as it’s a function of the pattern, not the person.
Not sure what you mean by manual measurments? Custom measurments can be useful when it’s measurement related and you can simplify a formula. For example… many pattern systems work with half measurements as you only draft half a pattern, but you take full measurements. So often I will use something like @Chest_Scale with a formula half of the bust_circ:
So if a draft calls for 1/6 the chest scale I can use @Chest_Scale / 6 instead of bust_circ / 2 / 6 or bust_circ / 12.
When possible… CW. But that is not always possible in which case a curve may need to be reversed- which in most cases will happen automatically. Let’s take this example:
There’s 2 possible pattern pieces… one with the curve going CW, one with the curve going CCW. With this one having rhe curve reversed:
You can place an object in what ever group you want. I created 2 groups… one I made hidden:
I placed Point A in visible group 1:
Everything else in Group2… so only point A is showing:
Clicking the “eye” on Group 2 now makes eveything visible again:
Clicking the eye on Group 1 makes point A hidden:
You can move objects from 1 group to another group: Now point A2 is in Group 1 - which is hidden:
Need to be more specific… everything can be formulized… except making a curve a specific length. There is a near infinite number of start and end point positions, and control point length & angle possibilities, many of which will produce the same length as others, but with a differing shape.
We use inches… and it all depends. Commercial patterns (like Butterrick, Simplicity, etc) will use 5/8" on most seams. Industrial machines and patterns however use increments of 1/4 inches… where 1/2" is the standard seam size size, 1/4 inch for things like collars and pocket flaps. Cutting and then sewing patterns with 5/8" SA on industrial machines is a PITA as the throat plates are marked in 1/4" increments, and most attachments are again in incrmenets of 1/4"
4 & 5 thread Overlock (serger) will be more like 3/8". In theatre we often would use additonal allowance so 3/4" and 1" is not uncommon.
Wearing ease is fairly universal. Anything else, it depends on how narrow of a group you want to be patterning for. Generally, you want to use the measurements file entries for maximum flexibility.
Thank you for explaining everything in such detail. You’ve really clarified my core understanding of variables and how to use custom variables effectively.
In the known measurements, there’s an option for half measurements (e.g., bust_arc_half_f ), so I added values for that, and it works for me.
I work in centimeters. but if i am drafting patterns for USA clients then should i add allawances in inches or cm can work? Please guide
As I’m still learning the concepts of this amazing software and pattern drafting, this is something new for me. If you could explain it, I’d really appreciate it.
If you’re working in cm, then do everything in cm, including the seam allowances. Just mention that your seam allowance is in cm. You can’t switch your patterns between Imperial & metric because 1 inch in metric is about 2.54 cm but 1 cm in Imperial is 0.3937 inches and if you have + 1cm in a formula in a pattern & switch to Imperial, that + 1 will become 2.54cm.
Not that it’s possible to easily change the pattern from one to the other.
Your USA clients will understand if you put a note in the instructions.
Depends on what the client is getting… are they getting the Seamly2D file or a layout export such as PDF? Since the pattern file is drafted in the given units, you would want the pattern in what ever units the client uses. On the other hand if you’re just providing a PDF, you can still work in cm, but for SA’s just use what ever cm values are close to 1/4", 1/2", 5/8" etc… so something .6 cm, , 1.25 cm, 1.6cm. Then note to the client what the allowances are in inches.
Your formulas can use conditional if - else statements using the c++ style ternary operator:
condition ? expression_if_true : expression_if_false
For ex: Say you have a measurement or variable called #num_of_darts, for it’s formula you could use something like:
@waist_circ >= 30 ? 2 : 1
where if the waist measurement >= 30 (in) the number of darts = 2. If the waist measurement is less than 30in then the number of darts = 1.
You can also nest conditionals inside as another expression:
@waist_circ >= 30 ? 2 : ( @waist_circ >=24 ? 1 : 0 )
where now if the waist is < 24 number of darts = 0. If the waist >= 24 AND < 30 then the number of darts = 1. If the waist >=30 then the number of darts = 2.
Other uses may be adapting pocket size to the size of jacket, allowing extra SA for larger sizes.
For more reading on the subject:
@UsamaIlyas_Cheema
On the other hand if you are using a measurement file, the measurements will be converted to the patten units… For ex:
Given this measurement file that’s in inches, but loaded into a pattern in cm will show the calculated value in cm:
where the 1" @ease has been calculated as 2.54cm in the pattern.
I will be providing PDF. And This will work for me :blush:
Thank you so much for the detailed explanation! It really makes sense and clicks in my head conceptually. I haven’t reached this level of practice yet, but I’m definitely saving this in my notes for the future. I appreciate you taking the time to explain it so clearly. Thanks again! :pray:
