Hi all. When I load an individual measurement chart, does it work in the detail mode too? I mean do I need to add all seam allowance or is the software doing it automatically? Thanks
Hi @helenetijou,
Once a measurements file is changed in a pattern file, everything will resize everywhere, including in the pattern detail. The seam allowances will remain as specified in the Options. You may need to tweak the curves, though, if you didn’t use formulas for the angles and lengths of the handles. The same with lines that you entered direct lengths. But anything using a formula from the measurements will resize beautifully.
this is just perfect @Grace. thanks
