Hi I can’t find any information on how to make a pattern piece of a circle. Ive drafted it along with other pattern pieces but now I can’t get it into a pattern piece because there are no nodes. What Should I be doing?
Adding this here as a FYI because it took some digging waaaay out in left field to find an answer. The issue on the Circle was that it was running counterclockwise. By reversing that direction I have a pattern piece which has also got the seam allowance happy. Found the answer for the circle in this post from @Douglas - Seam allowance on circle - Marge de couture sur cercle - #4 by Douglas
