Message error "Unable to prepare the data for creating the cutting plan"
Hello, when I want to create the cutting plane I get this error message
“Impossible de préparer les données pour la création du plan de coupe” translated as “Unable to prepare the data for creating the cutting plan”. It’s the first time I get its what does it means and how to get rid of it ?
Thank you !
Can you post your pattern & measurements, along with a screencap of the Layout print settings dialog? And I can take a look.
Here they are ! Thank you so much for your help !
castiane.smis (2,7 Ko) Pantalon à pont droit-Lansquenet.sm2d (93,9 Ko)
I’m not getting an error… it produces the layout ok.
If it’s still giving you an error… here are the layout settings I used.
