After changing then synchronising through the little window that shows up, everything function, no probleme, the new measurement have been properly changed. And then the little window pops up again, I make it disappear by cliking again “yes”, but the window will keep poping up every15-30sec.
Hello and welcome, @Luuminante
Yes, it is a problem. We’re trying to find what’s causing it. Just reply “No” the next time it pops up if you haven’t changed any measurements.
When this bug appears on my computer, I close Seamly and open it again and it’s gone most of the times.
Thank you for your answer ^^, I’ll reply “no” next time it shows up not needed. And yeah, I reboot seamly everytime too.
I thought it is because my cloud sync is messing with the file, turn out it is a bug. Thanks dev team for looking into it.
I have figured out what the issue is / was with the measurement sync. Apparently just opening a file also triggers the file watcher to send a file change, which was causing a recursion if one clicked Yes to sync the files. Dilaog pops up, Click yes… opens and reloads file… file change signal sent… Dialog pops up again… click yes… etc… etc.
I have fixed the recursion, and have completely removed the dialog and sync button / menu item as they provide no uselful function, other than to take more steps to sync and / or delay syncing. Now the measurements will automatically reload (sync) when you make changes to & save the current measurement file.
