When I have an open pattern, & close it using the Window menu, the whole program quits with an error: ExceptionBadId: Can't find object, id = 58 the id# varies, apparently based on how many objects are in the open file, but not equal to the number of items. It doesn’t seem to interfere with anything important, but it is a little annoying when I just wanted to switch to working on a different pattern without leaving the current pattern open! It happens both in the older,
shorty@Shelob:/media/shorty/Janus/Seamly2D$ seamly2d
Checked locale: "en_US"
DEBUG:Log file /home/shorty/.config/Seamly2DTeam/seamly2d-pid9292.log was locked.
DEBUG:Clearing old logs
DEBUG:Version: "0.6.0.1"
DEBUG:Build revision: unknown
DEBUG:"Based on Qt 5.9.5 (GCC 5.4.0 20160609, 64 bit)"
DEBUG:Built on Jan 13 2018 at 13:09:51
DEBUG:Command-line arguments: ("seamly2d")
& the appimage, (full debug list from load to fail.)
shorty@Shelob:/media/shorty/Janus/Seamly2D$ ./Seamly2D.AppImage
DEBUG:Log file /home/shorty/.config/Seamly2DTeam/seamly2d-pid9186.log was locked.
DEBUG:Build revision: Git:c403baf205f0
DEBUG:"Based on Qt 5.13.2 (GCC 7.5.0, 64 bit)"
DEBUG:Built on Jul 30 2020 at 19:27:10
DEBUG:Command-line arguments: ("./Seamly2D.AppImage")
DEBUG:Process ID: 9186
DEBUG:Checked locale: "en_US"
DEBUG:Initialization property browser.
DEBUG:Initialization groups dock.
DEBUG:Can't get tag Groups.
DEBUG:Updating recent file actions.
DEBUG:Reading settings.
DEBUG:Set current name to ""
DEBUG:Loading new file /home/shorty/seamly2d/patterns/PLEATED CIRCLE.val.
DEBUG:Loking file
DEBUG:Pattern file /home/shorty/seamly2d/patterns/PLEATED CIRCLE.val was locked.
DEBUG:Validation xml file /home/shorty/seamly2d/patterns/PLEATED CIRCLE.val.
DEBUG:Schema loaded.
DEBUG:Full parsing file
DEBUG:Parsing pattern.
DEBUG:Full parse.
DEBUG:Clearing container data for full parse.
DEBUG:Tag version.
DEBUG:Tag unit.
DEBUG:Tag description.
DEBUG:Tag notes.
DEBUG:Tag measurements.
DEBUG:Tag increments.
DEBUG:Tag draw.
DEBUG:Tag calculation.
DEBUG:Tag point.
DEBUG:Tag arc.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag line.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag line.
DEBUG:Tag line.
DEBUG:Tag point.
DEBUG:Tag line.
DEBUG:Tag modeling.
DEBUG:Tag point.
DEBUG:Tag arc.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag point.
DEBUG:Tag path.
DEBUG:Tag details.
DEBUG:Setting size to 26.4567 0
DEBUG:Actual size set to 26.4567
DEBUG:Tag groups.
DEBUG:Arrow tool.
DEBUG:Canceling tool.
DEBUG:Dialog closed.
DEBUG:Enabled arrow tool.
DEBUG:Set current name to "/home/shorty/seamly2d/patterns/PLEATED CIRCLE.val"
DEBUG:Updating recent file list.
DEBUG:Updating restore file list.
DEBUG:File loaded.
DEBUG:Arrow tool.
DEBUG:Show details scene
DEBUG:Show draw scene
DEBUG:Arrow tool.
DEBUG:Arrow tool.
DEBUG:Arrow tool.
DEBUG:Arrow tool.
DEBUG:Arrow tool.
DEBUG:File /home/shorty/seamly2d/patterns/PLEATED CIRCLE.val closed correct.
DEBUG:Reseting main window.
DEBUG:Unlocked pattern file.
DEBUG:Arrow tool.
DEBUG:Returned to Draw mode.
DEBUG:Clearing container data.
DEBUG:Clearing pattern.
CRITICAL:Error bad id. Program will be terminated.
DEBUG:Application closing.
This example is using the pleated circle which Grace posted recently: How to create Pleat markings - #5 by Grace, because it’s a small pattern, but it happened with all the others I tried as well.
