Moved curve shows different curve
Hi,
I am working on a trousers sloper and just finished the front, which looks fine. I wanted to move a traced copy to start working on the back, but the sideline looks like my curve adjustments are not taken in.
Anyone any idea wat could be wrong?
Thank you. Regards Éva Hose Grundschnitt.val (10.9 KB) Enticing.vit (1.5 KB)
Never mind, I drew a new curve, and that can be moved properly :slight_smile:
So glad you could get it working!
If you still have a copy with the weird curve, the devs would love to see the file!
I added it in the original post. It happened again, not sure which adjustment caused it, but finally it worked :slight_smile:
For sure… whether there’s a bug that needs fixing, or if we can improve input validation to avoid errors - it’s always helpful to have an example.
