Multisize pattern
like this: here: Is it possible to increase the size? - #4 by Grace you wrote:”All you need to do is to create a New file in SeamlyMe, select Multisize and your base size and height according to your standard measurements. Then add the codes for the measurement areas and (at each code) add the base value and the increment per size.”
what are these codes? thanks
Aliza
2 polubienia
