Parallelogram
Hallo maybe it is a good idea to add next to intersection an parallelogram tool.
it would save time to construct trouser back pockets, belt loops etc.
Idea select point A0#, A1# and A2#, result A3#
That does sound like a good idea. In the mean time you could use Point - Intersect Circles:
Makes no sense to add a tool that simply creates the 4th corner of a rectangle… there’s tools that can already do that. @Pneumarian suggested 1, here’s 2 others:
Point - On Perpendicular
Point - Length and Angle image
What makes more sense is a new Rectangle tool that has a Base point, Width, Length, and Angle attributes, and it creates 3 new points to form a rectangle at basepoint with a wdth and length rotated by n degrees.
OR better yet… we expand the idea further and make it a “Polygon” tool, where there’s also a Number of sides attribute where say we can enter a number from 3 to 8 to create Triangles, Rectangles, Pentagons, Hexagons, Septagons, and Octagons.
Expand it even further an add “Skew” attributes so that we can create a true “Parallelogram” or Rhombus.
For sure it can be done in multiple ways. It would be a time saving operation comparable with Midpoint on line.
