Pattern invisible
I can open the attached file but pattern remains invisible. The previously generated pieces however are visible. I have tried several other files but this is the only one that has trouble. What’s happened?
1715-25 waistcoat.sm2d (52.4 KB)
win11, seamly2d 2025.11.3.211
You have a point WAAAAY off to the right on the draft block:
Note you can zoom to any object in a group list by double clicling on it. That’s how I found the block.
