I worked to extend an older patternfile. Created the pdf I needed, closed the pattern. After printing I found an error I needed to correct. The file now doesn’t open, it throws an error. “element ‘groups’ is not allowed for current model.” I opened the file and found a tag. There isn’t a group defined (There was previously, but I deleted that group. Removing the from the file solved it. But I thought to make you aware. Win, Seamly 2D 2025.10.6.204
The error returns as soon as I work on the file. Anything added or deleted, then save the file and the returns in the file and this crashes SeamLy.
V4 - stomacher -V2.sm2d (17.7 KB)
V4 - stomacher -V2.sm2d (18.4 KB)
What is happening is that the Images folder is being placed before the Groups folder in the pattern file. It needs to be placed AFTER the Groups folder.
I’ve switched them around in the pattern above.
In order to prevent a repeat, you may need to update to a newer version of Seamly.
‘No new versions found’ (build of october 6th)
Thanks a lot, curious though as how that happened.
