Continuing the discussion from Setting Seam allowance and Internal Path while drafting from Draft to Piece:
@Douglas: Speaking of stuff you can’t do when first tracing off the pattern piece, using the April 11 AppImage on my Chromebook’s Linux VM, I just now traced off a piece that had Notches, & was kinda able to set the notches while in the tracing verification screen, except that after that I was unable to okay the tracing, even when I turned the notches back off. (Ed: Also happening on my Ubuntu Desktop.)
Here’s the error as it appears in my Terminal:
DEBUG:
Math parser error:
Message: "Unexpected token \"CurrentSeamAllowance\" found at position 0."
Expression: "CurrentSeamAllowance"
