Point or line delete
Hello Today,
Is it possible to delete any point or line or curve at anytime I want?
Since Seamly2D is a parametric pattern-drafting environment, it is not possible to delete any object upon which another object depends, (the one exception is if you want to delete an entire block upon which no measurements in other blocks depend.)
Not if the point or curve has been referenced in another tool or used in pattern piece. if a point has been used in multiple tools, you have to work backwards deleting each tool that use the point you want to delete.
