Print at home the pattern in A4
Good morning community :slight_smile:
I finally managed to create my first pattern. However I have not clue now how to print it at home.
I would like to print using A4 paper, but I have to split the pattern into pieces right ? so I can print them in A4 and then I can cello tape the pieces.
I don’t know how to do this. Any one can support on this ?
Once you have created a layout, you have several choices. What you want to do is print or export as a tiled PDF… accessible in the File menu. It will break up the layout into however many sheets the size your printer prefs are set to. Of course you’ll want to make sure your printer is set to A4. Printing will use Seamly to print the pattern. Exporting will allow you to save the PDF, and use the system to print the pattern.
What I highly suggest when tile printing is to include a square pattern piece of known size, like 4 in x 4in so that you can verify your printer settings are correct, and the pattern is printing to scale.
Hola. Este tema ya se explico por aca y le va a ayudar mucho.
El cuadro de prueba de 4 x 4 que te recomendo douglas es muy buena idea.
thank youuuuuuuuuuuuuuu !
thank you Damay ! Will try to follow it. :slight_smile:
