- When viewing the Linux debug output while drafting a pattern it is clogged with:
DEBUG:Draft Block Has Groups = 0
DEBUG:Can't get tag Groups.
- Or when there is a group, the first line has a
1
, & the second doesn’t occur. It doesn’t appear to take much processing power, but it outputs 1000 times so quickly that the debug console is practically meaningless; even when the benign qt window error occurs it keeps going. This occurs whether or not the group manager is open.
- The shoulder angle measurements, H36-40, have some issues.
- H36, H38, & H40 are marked as [length unit] measures instead of as degree measures.
- H37’s xml name:
shoulder_slope_neck_side_length
is misleading. Worse, & probably easier to fix, its Full Name, “Shoulder Slope length from Neck Side,” should be “Vertical Distance from Shoulder Point to Neck Side”. The Description matches the diagram.
- speaking of “Shoulder Tip,” iso standard appears to be “Shoulder Point.”
- H39 is not quite as bad. Its xml name is
shoulder_slope_neck_back_height
but its Full Name is “Shoulder Slope length from Neck Back” when “Vertical Distance from Shoulder Point to Neck Back” would make sense. The Description matches the diagram.
- H40 could have a default formula of
(90-shoulder_slope_neck_side_angle)
Yes… I became aware of this when debugging the macOS high cpu usage issue.
