Hello,
I’m new here. I’m struggling with seam allowances for curves, Valentina version 0.4.5 for mac. When I ask for seam allowances for curves sometimes I get a straight line. Could help me to understand if I’m doing something wrong?
Thanks
Hello,
Thanks
Hi,
Yes you do. Each object in detail should follow in clockwise directions. To correctly include a curve Valentina seeks start and end points of a curve segment. You should check and correct, if need, direction of a curve. Seek special option Reverse for this. If direction is wrong you will get wrong result.
So, if you want to fix:
Thanks!!! It works
