Programación
Hola.
Tengo entendido que Seamly 2D es de Codigo Abierto.
Si alguien quisiera aportar su ayuda en el programa desde la programación que tendría que estudiar desde 0.
Saludos
Hello.
I understand that Seamly2d is Open Source.
If someone wanted to contribute their help to the program from programming, what would they have to study from scratch?
Greetings
You need to know c++, the Qt API, Using Qt Creator - preferably with VS and kits installed so you can make the MSVC builds, using Git / Github, and then you have to learn the base code along with the preferred naming conventions & styling.
If you wanted to simply provide translations you need to know how to use the standalone Qt Linguist and Github.
Hola @Douglas Muchisimas gracias. Me muy útil esta información. Yo tengo cero conocimiento del tema. Pero me gustaría aprender. Saludos
Hello @Douglas Thanks a lot. This information is very useful to me. I have zero knowledge of the subject. But I would like to learn. Greetings
