Hi @Scholli
What is the formula used to create points A114 & 116? Because they have, with the resizing, moved off the arcs. You will find them close to point A or at a point relative to point A.
I would suggest that you lengthen the Arcs so that the larger sizes have more space to move in (even if you don’t use the whole length of the arcs for your pattern.
This seems to be a similar problem that was discussed here: Miscellaneous Minor Issues - #19 by Douglas
If you wish, please send me the files and I will have a look at it ![]()
