Are there Ready-To-Use Seamly2D Files of T-Shirts, Trousers etc.? So I can only change the measurements of these Ready-To-Use Files without pattern drafting from scratch?
Hi @optimusprime93, and welcome to the Seamly2D forum.
There are some patterns on the My Pattern Cloud that people have shared. You can just sign up and browse for what you want. ![]()
There are also some example patterns with the source code (available on Github)… there’s a trousers and men’s shirt pattern, and a T-shirt “test” pattern. I should look at including them as part of the distributions. Should just be a matter of adding a few lines to the build file(s) to copy the files while bundling a distribution.
Thank you very much for the answer.
